jtexas
Thread starter- Joined
- Oct 13, 2003
- 8,646
My daughter's 2001 Escape v6, about 85,000 miles, had it about a year, don't have prior service history.
Turns over normally, won't start.
Now she tells me, for a few weeks it's been intermittently failing to start, but only when warm and after driving several short trips. Usually resolved by waiting a couple-three hours.
Check engine light has not been on (I believe she would have noticed). Don't have a code reader. If it matters, the odometer test mode shows DTC 4352 but I haven't been able to decode it.
One other symptom: when you release the key, the engine shakes for a few seconds, feels & sounds like its "dieseling" (if you remember when cars used to do that); I don't believe it's dieseling though because it quits when you turn the key to "off". Daughter says, sometimes it did this when it didn't start, sometimes not. Now it happens every time. One or two cylinders firing maybe? Bad timing? If you ever crossed up a couple spark plug wires, it's almost kinda like that.
Internet research turned up some likely suspects for intermittent warm start problems: IAC, MAS, throttle position sensor, o2 sensor, fuel pressure. I had time yesterday to clean the IAC & MAS; didn't help.
I don't know how to narrow it down. Seems like if I have to resort to just throwing parts at it, might as well tow it to the shop.
Maybe somebody can recomend an economical code reader (say, under $50) that's good enough?
Couple questions about these COP spark plugs, I've heard you have to be careful with 'em --
*my plain old inline spark tester -- I assume that'll work? But what gap?
*Can I disable spark for compression testing by ground the leads with jumper wires?
Any other thoughts?
Thanks!
Any other thoughts?
Thanks!
