Name this Outdrive
tev2229
Below is a picture of my outdrive. It's from an '81 Searay with a 3.7L 470.
Can anyone name it? Is it a Mercruiser I? I am looking for a transom seal kit and I'm not sure what to get. Either a Sierra Part 18-2601 or 18-8205.
18-2601, indicates that it is for Mercruiser R, MR, ALPHA 1 (1983-90) S/N 6225577 & UP, ALPHA 1 SS (1986-89) S/N OA545004 & UP.
The kit 18-8205 is for Mercruiser I, R, MR, and Alpha I with exhaust tube. Would this be the right one?
Do I have an exhaust tube or not is what I've narrowed it down to. The boat is far away or I'd just look at it.
Thanks Everyone!
tev2229
Re: Name this Outdrive
Thanks Don, much appreciated. I ordered the proper re seal kit. I like George. My entire boat needs a name, and I think George is just right.
ziggy
i'm gonna speculate that the lower has been replaced with newer style alpha1 version. the back of the antiventilation plate looks squared off to me. i believe it'd be rounded if it was original model 1 lower. http://www.mercstuff.com/drive_idprealpha.htm
just a guess....
Ayuh,... Good eye Ziggy,... I didn't even notice,....
Don S
OK, so it's George the cross dresser :eek: :eek:
Anyway, it doesn't matter one bit for the type transom shield kit he gets. That's all still one drove. ;)
Ayuh,.... Cross dresser, or In-bred,...
Looks like George is tightly Coupled with his cousin, or is that sister,..??:eek::rolleyes::p
scipper77
Hello neighbor!!
That is an alpha one. Looks the same as mine, except mine is more banged up.
bigskiohio
Master Chief Petty Officer
alphas dont have the eye on top,right...... but the bottom is a another story.
Thanx Don for the id download been looking for that forever!!!!!!!!!!!
Bt Doctur
If we were to fit the flat Alpha cap , what would we call it then?
achris
More fish than mountain goat
....Do I have an exhaust tube or not is what I've narrowed it down to....
470s never had an exhaust tube, they had a bellows. Only V8s of a certain era had tubes.
And I'm with everybody else here.... That drive is a '1' drive (also called an 'MC-1'), and definitely not an Alpha 1. And Ziggy's good eye picked the later style lower unit. When you pull the lower off to service the water pump, you'll be able to determine which later unit it is. But even that doesn't make any difference to you unless you want to get inside the unit (DEEP inside).
Chris........
tev2229
What transom seal kit should I get? I thought it had a bellows last time I looked at it. So no exhaust tube?
achris
Somebody please correct me if I'm wrong, but I think you need kit # 18-2601. It contains an exhaust bellows.
HERE is the page I'm looking at....
Chris...........
scipper77
Hello neighbor!!
I stand corrected, I didn't see the ribs on the upper. The are pretty blurry in that picture. I'm a little embarrassed to have given misinformation. Sorry!!
Damien.
Hi.
From what i can tell the drive in the photo provided is a Mercruiser type-r.
The Alpha branding hadnt been bought into play yet as Merc hadnt developed the Bravo drive.
Tell tale signs, flat cav plate, lifting eye and design.
I could be wrong but im 80% certain.
Damien.
