RCSConstruction
- Mar 23, 2007
- 549
Re: My rapido longblock (pics)
Those water passage inserts are not needed. They will rust out anyhow..
Did you use some RTV at the corners of the intake manifold? I never did like using those rubber seals, I always use RTV all the way across.
Have you pressure tested those exhaust manifolds? Are they known 100% sure to be in good shape? One crack in them and your motor will be toast in short order.
Not having the windage tray MAY cause aeration of the oil and your lifters may not pump up correctly causing the valves to "tick". Pans with built in windage tray and scrapers are great but expensive.
That front timing cover may not last very long if your in salt water.
Thats a good days work, great job!![Cool :cool: :cool:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
