Pack Rat
Thread starter- Joined
- Jan 18, 2011
- 186
Some years ago I ran in Lake Superior with a Zodiac Mark II Compact (my avatar). I just picked up a JP-380 and will be using a Mercury 25hp on it.
Based on the archives I've been reading I will NOT be drilling new holes and bolting the motor to the transom. If I understand the outboard manual correctly the transom should be able to take 55 foot pounds when I tighten it down. I plan on using cable or chain thru the pre-drilled eyebolts on the transom to keep from losing the motor in case it does get loose.
The marine plywood transom pre-drilled eyebolts holes were not sealed with anything. Would you bother?
The 4 stroke outboard manual also says to avoid prolonged tipping in certain positions due to oil being able to run into the cylinders. I'm finding the weight a problem and the fact it can only be tipped certain ways doesn't help.
I wasn't planning on getting a trailer for this thing. With the old Zodiac I simply carried everything down to the shoreline and set it up. Some of you must have perfected ways to man handle 150 pound outboards? What's your methods?
