my lower end is very messy
Saskatoon2005
Master Chief Petty Officer
Re: my lower end is very messy
Can I change the lower geal housing spaghetti seal without removing the lower unit?
Saskatoon2005
Can I change the lower gear housing spaghetti seal without removing the lower unit?
Saskatoon2005
OBJ
It's easier to change it with the lower unit inverted. Hard to make it hold like it is. Pull the lower unit and prop it upside down. Then remove the lower half of the gear case. Might want to drain if of lube first to. Use a good gasket sealing compound when you put the spaghetti seal in the slot.
Saskatoon2005
thank-you for your help, it is very helpful and I will attend to it right now
