classiccat
"Captain" + Starmada Splash Of The Year 2020
- Dec 20, 2010
- 3,409
Thread Index:
Page-1 3/25/2013 to 3/25/2013
Recently I found myself gravitating to the Starcraft restoration threads. Specifically the SuperSport open bow is a configuration that really suits big river fishing; anchored-up and fishing as many rods as possible off of stern.
I restored a BlueFin Seahawk a few years back...and to be honest, I'm not mentally prepared for jumping back in the saddle again considering that I'm still making improvements to my current boat (console upgrades, transom replacement, final hull painting).
The problem is that my boat is on the small side and my buddies and I (as well as the fish!) aren't getting any lighter/smaller :lol:
For about 1 week, I communicated with a CL seller offering a 1975 18' SS for $2k.
We traded emails and I learned about the boat as well as kept tabs on another potential buyer. Once the other guy backed-out, I started planning my 4hr trek to meet the sellers/boat and hopefully make a deal! With some great advice several iboats members & my own personal experience, I went into the meeting with the seller well-prepared. The asking price IMO is reasonable if it only requires some minor cosmetic upgrades.
- Tinny Purchase
- Mob Introductions
- Evinrude LU Removal
- Evinrude LU Leak Revealed
- Evinrude Compression test (good tester)
- Evinrude Ignition Upgrades
- Pulling the Outboard Motor
- Evinrude LU bolt extraction
- Interior Demolition
- Transom Removal
- Cracked Kneebrace Revealed
- Bad Trailer Rollers Revealed
- Worn Spray Rail Revealed
- Interior Epoxy Removal
- Interior Hull Corrosion Revealed
- Evinrude H2O Intake Screen Replacement
- Evinrude Carb Rebuild
- Evinrude Dirty Fuel Pump
- Powerpilot Rebuild & Upgrades
- Bent Hull Revealed (Port outer chine)
- New Steering Wheels
- Evinrude Thermostat Replacement
- Evinrude Bent Exh Housing Revealed
- Evinrude Powerhead Removal
- Evinrude disassembly
- Spray Rail hole patch (part1)
- Evinrude skeg fix
- Evinrude Inner-exhaust assy
- Exterior Paint Stripping (Zip)
- Evinrude Exhaust cover removal
- Evinrude Tell-tail
- Evinrude Head Removal
- Exterior Paint/Epoxy Stripping
- 1-Man Flip (Hard way)
- Rib-end Cracks Revealed
- Bow Corrosion Revealed
- Evinrude Paint
- Fancy Schmancy Bow / Stern replacement lights
- Evinrude Assembly
- Evinrude Assy
- Evinrude Testfire
- Evinrude Leak
- Exterior Rib-end patches
- 1-Man Flip (Easy way)
- Evinrude Leak Fixed
- Hull bend
- Epoxy Plugs in Plywood
- Corrosion
- Nyalox Corrosion Removal
- Carpet glue Stripping
- Rivet Removal
- Corrosion
- Knee brace removal
- Paint Stripping
- Gunwale cap rivets
- Rear Seam Rivet Removal
- SR/OC Bracing
- SR/OC Bracing
- SR/OC Bracing
- Bow corrosion
- SR/OC Bracing
- Bow Rib Removal (check for corrosion)
- SR/OC Bracing
- Rib end Patches (Port Side)
- Cleco Suggestion
- Vulcan Cannon (Off topic...but cool!)
- 40sqft of Tin!
- Mob Request to lengthen & widen the SS
- Cracked Knee-brace Repair; Clecos put to use.
- Transom Z-bracket Removed
- Inner Hull Corrosion Treatments
- Transom Bracket idea (for transducers, speedos, etc.)
- Transom Skin Corrosion; Dremel action
- Drain fitting replacement
- Bow Deck Design 1.0
- Battery Placement Discussion
- Transom skin corrosion filling
- External kneebrace patch on bottom hull skin
- Speedo/'Ducer bracket fab & dry-fit
- external knee-brace patches
- bow patch
- internal rib-end patch
- spray-rail patch
- Spray rail patch continued (formed and holes transferred)
- Admiral's 1st shot at Riveting! Bow rib (removed to check for corrosion)
- Rework JB weld behind spray rail patch
- JB-weld holes in gunwales
- Riveted Transom z-brace, exterior knee-brace patches, rear seam and knee-brace
- Mob trying to get me to bite on a '75 135Hp
- Trailer Demo
- Trailer Axle/Suspension/Setup plans
- Trailer talk
- Port Bow Rib Riveted in place
- Foam Acquired
- Bow corrosion patch complete
- Trailer talk: axle & spring sizes
- Rusty Chevy Talk
- Transom rough cut
- New Trailer spring centers
- Transom lamination plan
- BK Onion Rings vs. White Castle
- Laminating a transom using epoxy/cabosil
![catfest2012a_zps3543a11c.jpg](http://i1310.photobucket.com/albums/s658/classiccatCB/1975%20STARCRAFT%2018ft%20SUPERSPORT/catfest2012a_zps3543a11c.jpg)
![catfest2011_zps6bd05f97.jpg](http://i1310.photobucket.com/albums/s658/classiccatCB/1975%20STARCRAFT%2018ft%20SUPERSPORT/catfest2011_zps6bd05f97.jpg)
![catfest2012b_zpsc753de0c.jpg](http://i1310.photobucket.com/albums/s658/classiccatCB/1975%20STARCRAFT%2018ft%20SUPERSPORT/catfest2012b_zpsc753de0c.jpg)
![75SS180_zps833f8149.jpg](http://i1310.photobucket.com/albums/s658/classiccatCB/1975%20STARCRAFT%2018ft%20SUPERSPORT/75SS180_zps833f8149.jpg)
