My 40hp Johnson quit turning over!! Help!
blaketippett
I got a boat from a guy and it was wired up and turning over, kinda, you had to hit the key switch a few times to get it to spin so i looked at the solenoid and seen it was a good bit old and rusted. well i seen a few wires had been cut and taped and not in use so i cut them and wire nutted them to make it a little neater inside the box with the solenoid and replaced the solenoid with a new one. now i have NOTHING! I have on the left my green and battery wire the right is my red wire going to my starter and the 2 white wires on top to engage the starter and my negatives are on the box with a wingnut. i can take an alligator clip and connect it to the left side with the red and green wire and touch it to the small white wire on the top of the solenoid and it will spin but nothing with the key switch...i have not moved any wires at all just replaced my solenoid...what may be causing this?
Honorary Supreme Mariner
You may get more help if you post a model # of your motor !----------Have you looked for a safety switch on the powerhead ??
oldboat1
It sounds like you have some significant corrosion issues. I like to use a simple continuity tester to troubleshoot (probe and light) -- would check key switch function (safety switch too), and check continuity from switch to solenoid. You may just need to clean connections.
Posting your model number would help for responses, as mentioned. In addition, there are links to some wiring diagrams in the stickies up at the top. Can also google with some basic info (yr/model number), and may get a hit.
Grub54891
And post some pics of the electrical jumble you have going on. Wire nuts are not allowed on boats, according to ABYC standards.
gm280
I have to actually wonder if you bought a starter solenoid that LOOKED like the correct one, or actually bought that same part numbered one? So many solenoids look alike but are very different in their wiring. And if you bought the wrong type, that would certainly account for nothing happening now when you turn the key.
I also agree with Grub, Stop using wire nuts. There is no where on any boat that wire nuts are a good choice. So remove all of them and either solder those connections with heat shrink tubing OR use proper crimp type connectors. JMHO!
