Nickypoo
- Mar 21, 2012
- 287
Re: 'Mr.Krabs' Another Bayliner Story
Hi 1lrover1,
Looks like you're making good progress.
I have one suggestion about your grinder "blade". I think I'm gonna have nightmares about that thing! Haha. I use a metal wheel that I think was designed for masonry. It's gold in color and the circumference is smooth with small bits of diamond or something embedded. It cuts through fiberglass like butter and will cut through wood slowly too. It doesnt wear down like the abrasive blades. Anyhow, it's pretty safe because if I accidentally touch it then I just get my skin a little scuffed up. I can foresee your blade getting one of those teeth caught on something and kicking back onto your arm.
Also the foam comes out with a shovel. The bigger sections you can pop out the better. I used a roofing shovel used to remove shingles and such which is a little more stout than a regular shovel.
And I completely agree with Teamster. The foam becomes a big part of the structure of the hull. Use the pour foam to replace it.
Anyway, just some thoughts. Good luck!
Hi 1lrover1,
