Moving oil tank. Question about electical connections?
stretch
The tank is in the back corner of the deck next to the motor. I want to move it under the console. Motor is a 2002 90 Johnson. There is a cable with 2 wires? in it that is not long enough. <br />Can I just cut the wires and souder an extension of similar gauge wire in the middle? <br /> Total length from the motor, through the tunnel, to under the console will be about 15 feet.
ICEMAN
Re: Moving oil tank. Question about electical connections?
HI, You can add wire to make it longer, Just be aware that when you add the wire, make sure you connect the wires in thier correct location. Don't cross them. :)
