Silverbullet555
- Mar 13, 2011
- 621
I am finishing up the install of a swim platform on our cobalt. I need to mount the two support tubes and the perfect mounting location would use one of the screws one the trim tabs. I would be able to through bolt it and there is a metal backing plate as well. There would be two bolts holding the tube to the transom so all the weight would not be on only one bolt.
If I through bolt and mount it right over the trim tab mount is that going to create a problem? I will be going to a larger bolt to compensate for the additional stress on that location.
