motorshuts down
thebestone
Hi this my first time here
my issue is that when i try to go fast my motor start to shut down , i have to pump the ball to keep it giong is there adjustment on the motor \
motor is a 9.8 murcury electric start:confused:
JB
Re: motorshuts down
Howdy bestone.
Welcome to iboats. :)
Your engine is not getting enough gas to go fast.
This problem is usually because of some restriction in the fuel line, a failing fuel pump, poorly vented fuel tank or a trouble with the anti-siphon valve in the outlet of the fuel tank.
Hand pumping the primer bulb is strong enough to overcome the problem.
Check those things out and let us know what you find.
Good luck. :)
