i need a wire diagram for a motorguide brute. compitition dura amp 2 says on the head that's white in color. now the motor that's Black from whats left on the decal says 45 lb thrust. made in mexico. the foot pedal is black low profile plastic says 1985. that normal white head black motor? appears to be 12 volt. went to see if it ran? nope nothing at all. moved the switch from low to high nothing. now after i brought it back inside to look it over i see there is a reset button under the pedal assy. also noticed that the run switch on the pedal it self has two wires going to it.. thing is there is a extra wire with a terminal that is long side the switch but there are only two screws on the switch no idea where that third wire goes. on the hi speed by pass switch was falling apart. so i used a jumper wire the hi speed bypass has two wires to it but there are three terminals on it. any hints or know of a wire diagram for it ? i hope i made some sense of this.
