Re: Motor swap
I just put a '94 150 Johnson on my pontoon and took a '78 Evinrude 140 off. The motor wiring was plug-and-play but I looked close to make sure the pins were the same in the plug. The '94 had a VRO oil system so I just disconnected it and I run mixed gas-oil. There are several threads in the Johnson - Evinrude section on how to do this. The only thing I had to modify was the trim controls. The older 140 Evinrude used a three wire trim motor and a external relay pack while the later model Johnson motor used relays in the motor. Basically, the older motor used external trim controls whereas the newer motor uses internal trim controls. If both of you're motors have trim relays up at the top front inside the motor, you probably won't have to make the modification I did. When I went the other way and put the '78 model 140 on the '94 boat I had to build a relay pack with two relays. Being an HVAC/controls guy figuring out switches, controls and relays are second nature so it wasn't a problem.
