capt-stuck
Thread starter- Joined
- Jan 31, 2005
- 22
I have a 1985 85hp Force. The motor was sitting for a year or two when i got it. I got the motor running, changed the lower seals, cleaned the carbs, put on a new ignition coil for top cylinder,put on new stater, and the compression is 125,120,125 top to bottom. anyway. the day before i took the boat on the water i had it running. the morning before i started it up again to make sure it was running good, and it was. i get out to the water. start the boat at the dock, and after everybody was in we took off on our maiden voyage i got about to the marker and the boat started spitting and sputtering, then finally conked out. So my first trip out and i got stuck in the cahnnel. I had to be towed back to the dock, and went home with my tail between my legs. The question finally is: Where do I begin? what should i start looking for the problem? any suggestion will help. oh yeah, i bout the seleco book, and it should be here today.. Thanks
