Motor Pod
Bottomfeeder1980
Hello all. I am hoping someone here could hold information regarding the motor pod dimensions for a 2000 Lowe suncruiser Trinidad 244. Specifically the interior dimensions. I have to replace the factory fuel cell but I would like to explore options for relocation off the deck. Has anyone found successfully done this? I currently fuel capacity is approximately 24 gal and would like to avoid losing capacity.
jlh3rd
?. Can’t you measure it yourself?
I’ve got an ‘06 suncruiser, 24 gallon tank. I guess you could investigate the newer toons that have tanks mounted centrally, but I’d see no way to put a center tank in my motor pod as it is triangular, short, and with angled in sides. Bet yours is the same.
Bottomfeeder1980
For reasons you stated, measuring the angles and lifts make it difficult to translate into a workable piece for comparison. I have seen tanks made for this specific application. Perhaps someone out there has gone boldly before me
jlh3rd
Ah, got it.
try investigating this.
