Motor Mounts and Yokes
dpatterson
Motor Mounts and Yokes 90 ELPTO.
Anyone had to replace these? Looks like the power head needs to be removed. My retaining ring off the bottom yoke fell off and is resting around the shift shaft. It's rusted badly so I assume it should be replaced as well?
Any advise on this would help.
Also...Plug wires? Best place to get them? Whats with the screw terminal in the coil? Whatever happend to a regular clip in? Find that my wire's pop off when putting the engine cover back on.
Re: Motor Mounts and Yokes
What is the year of that motor? Does it have a dissy?
The older inline motors required that the powerhead be removed to access the upper motor mounts.
dpatterson
It's a 1999.
By the looks of it I might have to remove the head but I'm not sure. Bit uneasy about the ring coming off, unless it just happens with time.
