- Jul 23, 2011
- 52,228
Here are a few shots of the cracks in the fiber glass on the engine mounts
from what I am putting together, the prior owner had the bilge pump replaced (and not with an auto float switch). the bilge pump wasnt working and there was water in the bilge for a bit. water has apparently wicked down the mount lag bolts.
the wood is still solid in the area that I cut the fiberglass away on both sides, however I will still be replacing it and rebuilding the mounts.
I can build up out of plywood and PB, or I can carve out of large piece of ash or oak. I also have some dry pressure treated. any pro's / con's?
can someone estimate the materials I need to order or pick-up from West Marine?
Thanks in advance.
Thanks in advance.
