Motor height question
JJB
I have a 20' Bayliner cuddy cabin deep V hull . I wanted to know where do you measure from for the correct mounting height . Is it from the deepest part of the V in the hull ?
Frank Acampora
Re: Motor height question
Start with the engine anti-cavitation/ventilation plate at the apex of the Vee if you can get it that low (transom height varies from brand to brand). If you have a Force engine use the top mounting holes in the engine mounting clamps or brackets. that way you can raise the engine 1 inch without re-drilling the bolt holes.
See what kind of holding you get in rather sharp turns. If you have power trim and it ventilates like crazy at the cruise trim setting, leave it there. If it ventilates only a little, try raising it the inch since some amount of ventilation in turns can be controlled by tucking trim in.
steelespike
The condition and design of your prop will determine how high you can raise the motor.one inch can give you 2 to 3 mph under ideal conditions.
JJB
Would it also give me more Rpm if raised one inch or more ?
steelespike
Yes it would give some more rpm assuming you get a noticeable increase in speed.
