motor cover question
krovar
this might be a dumb question but how dose air get to the carbs with the hood on, the reason i ask this yesterday while working on the motor i noticed the motor would idle at 1100 rpm without hood put hood on the rpm will drop to 700 to 800 rpm.
Rick.
Re: motor cover question
If you look closely the hoods are vented. Sounds to me like yours is plugged or it was just unrelated that you RPM dropped at the same time the hood went on. If it fit so well that we lost 400 at idle we would never get to WOT. Best of luck. Rick.
krovar
this is a 1977 johnson 115 there is no vents in this cover that i can find
Rick.
I'm certainly not familiar with your engine but I have to believe the engineers would have figured something clever by 1977. If you think about it they just would not run if the cowl was air tight. Rick.
krovar
if i could find out how to send pictures i would, but ill bet if you turn it upside down it would hold water
