Motor Cable Assembly 582061 and 583099 modification and interchange.
JohnnyMat
So I have been scouring the typical sites looking for a good used wiring harness for my 1982 J60ELCNM which requires part number 582061. I couldn't find a suitable replacement without going the the "brand new" route for $117 and up. I kept searching and came across the 583099 from a 40-50HP (this particular one came off of a J40ELCOB). After quite some time of staring and comparing on my comp screen, I went ahead and pulled the trigger on a very nice $50 583099. The guy who sold it to me said it would not fit my engine but my eyes were telling me a different story. :)
After getting the harness I went over the two (old/new) with a fine tooth comb. The plug and pin placement are identical, the length (from what I can tell) is identical, wiring colors are identical, wire gauges are identical, and end connectors are identical. That said the ONLY difference between the two is the 583099 has two temp sensor wires that splice from a single lead. They are the same color wire exiting the harness and the splice for them is buried in the main trunk of the assembly.
My J60ELCNM only requires one temp sensor wire so I will simply tape the extra one back to use later if ever needed. These wires have the small knife disconnect on them (PN 038808).
In order to use an original harness from the J60ELCNM (PN 582061) instead of the 583099, you would simply need to splice a second knife disconnect onto the existing single lead to make two available. A very simple and cost saving retrofit IMO.
I thought this may be somewhat useful information because P/N 583099 is no longer available/obsolete. Used ones are out there and were easier to find than the 582061 (replaced by P/Ns: 583005, 0767968, 413-9915 aftermarket). I cannot confirm the same modification will work on the replacement P/N's.
I was also going to attempt to rebuild my original harness, but the wires were dry rotted all the way back to the plug. You'll see in the pics it was pretty crusty (understatement).
If anyone has any other questions about this modification and setup, or if I missed something in the explanation, please feel free to leave a post.
Otherwise I hope this info was useful and I hope it can help someone out there in boat land. Happy Boating!
JohnnyMat
No Title
My harness was so bad that a few of the wires completely broke off. If you're looking for them, there either in the bottom of the engine housing or they are dust on my garage floor. :)
Sorry but the captions are not lining up with pictures.
JohnnyMat
So one thing I have to update, I overlooked one connector. The pin connector that goes into the coil plug is a male end on the 582061 and a female on the 583099. I carefully removed each crimp and swapped out the male end for my mod. You can also just as easily splice the wire if your situation allows it. Mine didn't, because the old wiring was shot right up to the plug.
My apologies for the misinformation in the original post.
My motor is running like a champ now though! :)
oldboat1
It's good service you do, johnnymat. Have a feeling your thread is going to pop up in somebody's search when they have a pressing need. Specialized stuff, described and detailed really well, imo.
ed....:hail:
JohnnyMat
ed....:hail:
I appreciate the kind words Ed and I definitely hope it saves someone time! I'm just a newbie to the boat scene though and just wanted to share something I ran into! :D
