Morse Steering Ram Leaking
20pilot
My steering ram started to leak and I am looking to replace the seal. I showed the ram to several people and no one was able to identify what seal kit was needed. I knew that you guys would have the answer for me or point me in the right direction. I am attaching several pictures which may help to identify the seal kit needed. Thanks in advance for the help!
Bob_VT
I am not sure about replacing the seals unless you have a good hydraulic shop in town. I am pretty sure teleflex bougt out morse and parts are available from iboats but they are complete cylinders which really reasonable in price.
jerryjerry05
I bought an o-ring assortment from someplace a few years ago.
It has rescued me a number of times.Yesterday being the latest.
Take it apart and see if you can just replace the O-ring.
If not??
Start with PB blaster and some heat. Don't get it so hot it ruins everything.
More PB and some heat.
Then try to take it apart.
This might be the one you need?
Send your pics to Teleflex.
1-HS5152 Old Style Seals
In Stock1$49.95
1-HS5153 Side Mount Seals
In Stock1$42.95
1-HS5157 Front Mount Seals With Wrench
In Stock1$109.39
1-HS5167 Front Mount Seals Without Wrench
In Stock1$88.49
