Mooring cover
Mama D
Hello All, we are very new to the pontoon world as we have just purchased a 2010 princecraft Versailes 23. She is in mint condition but we did not get a tutorial on applying the mooring cover. I have been unable to find anything in the manual.
many tips or instruction would be very helpful. Thank you in advance and I am so happy I found the forum.
welcome aboard
mooring cover should be like putting on a fitted sheet on the bed, however with a tent pole or two in the middle and some straps on the side.
it will become obvious as you start to install it.
Mama D
Thank you. It was pretty straight forward once I found a starting point. It was a bit intimidating goin from a bow rider cover to something this big. Easy peas though now that I have done it once. Thank you for the encouragement.
ahicks
One tip I'd share would be to get a magic marker out, and mark the 4 corners (LF, RF, RR, LR) and left and right mid ship (LM, RM). Do that big enough where it's easily seen. That will prove to be a HUGE time saver the next time you need to install the cover. No more installing, only to have to start over again because it's backwards for instance.
Mama D
Thank you for the tip. That is such a good idea.
poconojoe
Use the marker on the underside of the cover.
The previous owner of my boat drew an arrow under the very front of the bow cover. After a while, I really didn't need the arrow. I can tell what goes where from repetition.
