FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
i just broke my strut and i bent the prop shaft , any one now what are the sizes of my shaft to try to get one on line or any one know if i can repair it thanks
Re: moomba movius 2000 need help with my propeller shaft
Check with your local Moomba dealer to find what they installed in the boat. You could also check with your local prop repair shop. They normally so prop shaft, strut, and rudder repair.
Remove your damaged prop and prop shaft, bring that assembly to the dealer and ask for the exact replacement. Pretty simple way to make sure you get the right stuff. If at that time you want to upgrade to the 4 bladed prop they will be able to tell you right then and there if you can do it.
