Montgomery Ward 6hp fuel setup?
AlekMack
I have a Montgomery Ward registered In (1975) . Basically I’m looking for some guidance on what all I need to get this running . I have a 3/8 hose but wrong quick disconnects
Tank has nothing but a open hole where the fitting goes. New to the outboard hobby
95EDB00C-B9E7-4F2D-B88C-30BFC70246E5.jpeg8DD068E9-55B8-477B-BA23-3C59DFB0A24B.jpegEE2ABA4D-2586-4D3D-BCB3-F9D0A8AF7745.jpeg5C58040A-750B-468A-9CD3-F6E577CC6BFB.jpeg075924FA-6395-4A7C-A9F2-524163294E76.jpeg
brim_buster
Goto Walmart get you a new tank. Get a Sierra primer ball. Get about 4 ft of good fuel line. Your probably not gonna find a female quick connect for that motor. Get a fuel filter to put in-line on your hose past the primer ball on the motor side. Take that quick connect off the motor and run fuel line to carb. It might go 3/8 to a 1/4 at the carb. Then you will have to figure out if the motor runs.
