minn kote 824 turbo board?
shad1234
I need a minn kote board for 824 turbo ap. I bought the motor and the board was bad. They don't have them at minn kote, So my only opption would be to find a board from a old motor. Or does anybody know if I can use a newer board and just splice the old plug onto the newer board? Thanks shad j
4JawChuck
Re: minn kote 824 turbo board?
There is a replacement board available, just do a search for Minn Kota repair parts in Google and you will find suppliers all over the web. Your unit is 24V so you need the 24V board. I have a 824 here I use for parts on my 812 (12V motor) and they are very similar except for the control board and motor housing.
Here is an online parts supplier for your 824;
http://www.trollingmotorparts.com/default.aspx?act=documentdetails.aspx&Documentid=188&category=Minnkota Motor Diagrams 1992&MenuGroup=Home&SMID=186&SMSubID=52&nosearchprompt=1
BTW make sure its not your foot pedal, the typical procedure for repairing these motors is foot pedal first then control board, there was a link to a Minn Kota repair manual in this thread for download, not sure if its still available. It has invaluable information on testing the foot pedal and other stuff;
http://forums.iboats.com/showthread.php?t=359150
shad1234
Well I went to test the motor and the board let the smoke out. So I couldn't even tell if anything worked. I ohm'ed out the motor it was somewhere around 26.26 ohms. If that means anything. thanks for your help.
