easydoesit13
Thread starter- Joined
- May 4, 2010
- 2
I bought a older 20 HP mercury engine(1976). I then discovered the lower end had no oil. I serviced with oil and ran (water muffs) to find the oil milky after a short run. I then changed the water pump and ran it with water muffs and but the oil still goes milky again after running for a short time. The shaft seal by the water pump is new and seeing as how I'm using water muffs I don't see water getting in through the prop shaft seal. I'm confused and would appreciate some suggestions as to my next move. THANKS
