mfgniagara
Thread starter- Joined
- Aug 17, 2010
- 92
First post, been browsing here for a few months now.
I was just given the above boat, I believe it's a 1965 or 66 model.
Its in decent shape, no leaks, with some fade and a way too big motor.
(85hp Merc 850). It's on a 2007 bunk trailer, and runs great. I added a battery and did some cleaning so far. It's first water test was a bit scary, it shot right up on plane and according to my GPS I was going 56 mph when I decided it no longer felt safe.
I have a later model Mercury 50 to hang on it.
The bad part is that the transom is getting soft, so I went ahead and got the supplies to do that real soon.
I have two main questions, first, how can I get the second or lower drain plug tube back in place without cutting out the original deck?
I really want to make the boat look factory original when all done, I hate to have to cut into the deck where it meets the transom to be sure that tube is in place and sealed to the transom? The original tube is rolled on both the inside and outside edges and was no doubt installed during the hull molding process.
Second question, this boat has no seats, the last owner was using a stainless folding deck chair that looks like it came off the Titanic. There's two of them and they don't even fit side by side in this boat. Let alone they're dangerous not being secured in that they tend to slide rearward as the bow rises on take off.
I have both a pair of aluminum pedestal seats and Todd captain chairs, plus a set of back to back seats. My concern is that the deck isn't made to have pedestals bolted to it, and that the back to back seats won't give me enough room to pass in between them easily as the front corner of the lower seat box hits the tapered outer hull and won't sit well inline with the steering wheel.
Another option I'm thinking is to buy one of those cooler seats, mount it dead center and it'll solve another concern as well, which is running the boat alone and balance. Being able to sit or stand in the center will keep my 6'4" tall, 350lb self from making the boat list to Starboard all the time.
