Mercury upgrade
marbles67
I bought a Smoker craft, with a blown 1981 mercury, im looking at a 2000 mercury 2stroke
What will I have to do for controls ect to have this working on my boat
Re: Mercury upgrade
Ayuh,.... Welcome Aboard,... Are these 9hp, or 90hp,..??
marbles67
Re: Mercury upgrade
So i just looked at the motor, and on first glance in New it wasn't fromm2000
Turns out it's. A 1994 hes now asking 1700,i found a 1999 for 1800not sure what to buy and what I should be doing about controls, any advice would be great
wired247
Re: Mercury upgrade
Perhaps if you were more specific about what motor it is you'd get some advice based on your information. Theres a lot of different Mercury motors in a given year.
marbles67
Re: Mercury upgrade
not sure how much more info you need?im talking about 40hp Mercury
Maybe yiuecsn be more specific so i can post Additional information?
marbles67
Re: Mercury upgrade
My boat came with 1981mercury 50hp
I looked at a 1994 mercury 40hp two stroke, it's a one owner motor woth1500 worth the work done in 2010
Compression is rock solid,he wants 1700
There's another 40hp Mercury 1999 the guy wants 1800 for that
What control changes ect would I need to do for either of these motor hope this is a little clearer
marbles67
Re: Mercury upgrade
OK so i bought the 40 hp motor 1999 two stroke, what will I have to do
As i stated earlier my boat has a 1981mercury 50hp any advice would be great
Do I need new cables ecgo?
wired247
Re: Mercury upgrade
Everything should be the same. Should bolt up and plug in.
Re: Mercury upgrade
Shift and throttle cables should work fine. Electrical is very likely completely different, but may be adapted. Steering and fuel lines are compatable or can be made compatable, easy.
marbles67
Re: Mercury upgrade
So it turns out the motor is a 1996,the, linkeage looks way different as i thought it would the shifter and tbrottle
Portion, other than that looks pretty close, would I just swap his whole controller over shifter ect?how does the shifter linkeage come off the motor?i feel silly asking all the questions in just have never owned a boat, plus I will have to dril new holes to mount the motor
It was easier putting transmission and engine in cars
Re: Mercury upgrade
The throttle and shift cables simply disconnect at the motor. On the '81, there are two 3/8" nuts that need to be removed. Then remove the barrell nuts from the clamp and pull the cables out of the motor. They will install the same way, except the clamp is a piece of plastic.
Re: Mercury upgrade
Unless you have a harness from the '96 motor, you will need to splice it somehow.
