Mercury Trim Wiring - new control box
zracer
I have a 1986 XR2 with power trim. The control box broke and I am replacing it with the new style box. My question is on trim/tilt wiring. Here is what I have;
New Box:
Blue/White
Green/White
Tan
Brown/White
Motor:
Blue/White - up
Green/White- down
Red- fused power
Black/white- goes to trim sensor
Where does the brown/white and tan go?
Also,
My warning horn is also not beeping when I power on the key? The new control box has a built in warning horn, the old box had an external. The warning horn was working with the old box.
Everything else appears to be working.
joed
Re: Mercury Trim Wiring - new control box
Tan is the warning horn. Ground it and the horn goes off. Usually it is connected to the overheat sensor and the oil warning module. The warning module is the part that gives the startup test beep.
zracer
Update:
New Box:
Blue/White trim up
Green/White trim down
Tan - temperature gauge
Brown/White trim gauge
Control box is 881170A20 with Power Trim w/ key switch and 20' harness
