Re: Mercury outboard coil recalls
This coil is not divided internally, it is a single coil with two outputs. Only way it could act up is if plug wire connection was internally failing. The only problem I have seen with these coils is wire burning into inside plug boot. If coil was failing it would also affect cylinder #1. Swap the #1 lead with #3 and see if problem follows.....
