VERY intermittent problem continues for over a year, can't seem to identify the problem. The engine is a 2017 Mercury 150 4-stroke mounted on a Tracker boat. The engine has 240 hours on it and the problem started occurring at about 170 hours.
Symptom:
Motor runs great most of the times, however it intermittently begins to miss and sputter. It may run well for an hour or two, then begin to miss and sputter, I'll stop for a while and then the engine runs good again, sometimes for an hour or more, sometimes will miss again after 20 min.
Curiously, the engine ran symptom free for about 30 hours throughout the summer, then began the intermittent missing a month or two ago.
Things I've tried:
The intermittent missing seems like the engine is starving for gas so I installed a clear gas filter in the visible part of the gas line going to the engine so I can observe fuel flow. Although the fuel doesn't completely fill the filter, there always seems to be fuel moving through the filter, even when engine sputtering.
This has been an ongoing issue so have obviously run significant amounts of fuel from different sources as well as added fuel conditioner. Also tried new spark plugs and replaced the low pressure fuel filter inside the engine 3 times.
I took the boat to the dealer just before the 3 year warranty ended. The dealer checked the ECM and saw no errors or faults logged. They said the clear filter I put in the fuel line is likely the cause. I explained to them that I put the filter in the fuel line to help diagnose the problem. I wasn't impressed with the dealer although with the problem being so intermittent, it would be difficult without any ECM errors to guide them.
Again thinking the intermittent missing could be fuel supply related, I connected a 6-gallon auxiliary fuel tank thinking that it would eliminate the built in fuel tank, hoses, fuel demand valve, gas cap vent valves, etc. The intermittent missing occurred while running on this auxiliary tank too. So at this point I'm tending to believe that the problem is within the engine and not the fuel supply system. Again, this is very intermittent, sometimes I could run through the 6 gallon tank without problems, then next time it would begin missing. The 150 obviously would burn through the 6 gallons in about 80 min.
If anyone has any suggestions please let me know. The boat is out of warranty and I have zeor confidence in the local dealer so I'm on my own but luckilly experienced with most outboard repairs. I'm thinking of replacing the low pressure fuel pump or maybe a coil and moving it through the 4 positions. Again, any relevant information or suggestions would be very much appreciated.
Symptom:
Things I've tried:
