snowbrd84
Thread starter- Joined
- Sep 23, 2012
- 215
I have my '86 Mercury Blackmax 150 completely apart to replace a piston. I would like to completely remove the oil injection and move to pre-mix as I absolutely do not trust the oil injection and would rather have the piece of mind that I know its getting oil with pre-mix.
So can I just remove the plastic gear from the crank shaft and install a block-off plate where the oil pump was on the block and then install a plug where the pressure output is for the oil tank? Is that it? Am I missing anything?
