Mercury, Merc 200, 1975, 20 hp lower unit disasembly
Chris52796
i'm replacing the cam and reverse lock and i need only manual to put it back together.
I need to know if there is a shortcut instead of taking the lower unit all apart
Chinewalker
Re: Mercury, Merc 200, 1975, 20 hp lower unit disasembly
If you took the shift rod out of the lower unit, then you will need to pull it apart to put it back in the shift cam. No way to align it otherwise...
Chris52796
Its the cam i need to get out and replace so i need to know if it is a easy job
