mercury marine 110 9.8hp
mercurymarine98
I replaced the rings on this motor. I am looking for the torque spec to put the
motor back together. thanks
green4themoney
Re: mercury marine 110 9.8hp
just need the year and ill give you all the specs for the PH
mercurymarine98
further to this engine. The serial number is 7122065 so as far as I can tell I believe it is a 1985. Does this help. Thanks again.
green4themoney
bearing carrier nut - 60 ft lbs
carburator mounting locknut - 80 in lbs
center main bearing lockscrew (3) - 42 in lbs
center main bearing reed stop screw - 22 in lbs
coil terminal nuts - 30 in lbs
connecting rod nuts - 15 ft lbs
crankcase to cylinder block - 95 in lbs
cylinder block cover - 90 in lbs
exaust outer cover - 70 in lbs
flywheel to crankshaft - 35 ft lbs
powerhead to driveshaft housing - 80 in lbs
reed block clamping screws - 25 in lbs
spark plugs - 20 ft lbs
stator mounting screws - 30 in lbs
transfer port cover screws - 45 in lbs
hope this helps
mercurymarine98
That helps very much. I do not know if that last statement was correct english but I thank you very much for the fast information. I am just going to put the engine back together. cheers
mercurymarine98
Again I am back in this forum looking for some info on a mercury marine 110 9.8hp engine.Year 1985. I am trying to time this motor and do not have a book or know if this motor can be timed. When I took the the engine apart and the flywheel off the magnetic strip on the inside of the flywheel was removed. Does the positioning of this strip effect the timing of of the motor. Any info on how to go about timing the engine or where I can aquire a manual would be greatly apperciated. Thanks again in advance.
5556grant
torex spec on a 81merc. 200 hp
can any help torex specs for i can put back together thanks serial number is 5880459
