Mercury F50 EFI Wiring Index
twincam
Hello
First of all, i have to say that my english isnt that good, so please remember that thanks.
My Problem is, that i have no wiring diagram for my new MERCURY F50 ELPT EFI
On the Quicksilver/Mercury Remote Control is an 14 Pin Connector to the engine, an 9 Pin Connector to the Smartcraft Instruments and there are 5 Cables and that 5 cables, i dont understand what they are for.
For better explanaition i will add some Pictures of the Box and the Cables
The 5 cables are:
PINK
YELLOW- black stripe
BLUE- white stripe
GREEN- white stripe
BROWN- blue stripe
Does anyone know what these cables are for?
My next problem is that i have an analog RPM, and TRIM Module
How do i connect this?
Are the cables im am looking for on The 9 Pin Connector Smartcrfat Cable?
But the Bigger Question are the 5 Cables
It would be very nice if you could help me out
Best thanks
Grettings Chris
roncoop75
Re: Mercury F50 EFI Wiring Index
Well... having just changed my remote, on mine, BLUE-white strip and GREEN-white stripe are tilt up and down. Not sure which is up and which is down, don't remember.
The BROWN-*white* stripe (on mine the stripe was white) came from the trim indicator sending unit.
I'm betting Merc has left the colors alone all these years, but not sure.
Have no clue on the other two.
You need a factory service manual. Mine explained all this.
twincam
Hy
Thanks for reply
Where do i get this for Modell 2010?
Greets
twincam
I googled for hours, but i dont found anything that brings me forward, does noone have the same Control Box?
Is this engine model the same as it in 2002 was?
Moike
I have same issue, and wonder if you have ever had this resolved. I have a 10 pin (only nine are active) conector and the same five loose wires. I want to install a tac and cannot find any information on the wiring. My O/B is a 25 Jet but is otherwise same controls......
Mike
Hello
The 5 cables are:
PINK
BLUE- white stripe
GREEN- white stripe
BROWN- blue stripe
Best thanks
Grettings Chris
twincam
Hi, i have resolved this problem
This Part should help you out
Part Number: 84-892990-T01
This is an Cable that u can put in the smartcraft 9pin connector, and connect ur tach, trim gauge and so on.
costs 25dollar
look here:
http://www.ishopmarine.com/partList/0/4/C0083964/MM~A0000009~M0003998~M0004000~C0083964
84892990T01 1 EA 24.86 HARNESS ASSEMBLY, Analog Gauge
All Cables are shown for what they are for, if u dont want to buy that cable i can help u out with the correct wiring colours and what they are for.
best greets
twincam
the 5 loose cables are not used, only 4 a second engine
best regards
iltano
Hi TWINCAM,
could you please post the wiring colors and signals meaning of the adaptor cable. Thanks a lot.
best regards
