Mercury difficult to turn left and right (steering)
briaineo
Hi
I have an old 1974 Mercury 402 which has become difficult (very stiff) to turn left or right.
What happened was the motor was stored on the back of the boat and the cover was leaking of which i was unaware.
I disconnected the steering linkage to the steering wheel and with just the motor on the back of the boat it is difficult to push the motor to the left or right by hand.
Any ideas on how to get her steering freely again?
thanks
gm280
First thing you need to do is determine if the stiff steering is the actual motor OR the cable from the steering wheel. Once you determine that, then look for a fix. Most engines have an adjustment to stiffen or loosen the steering. If that adjustment doesn't help, then it has to be the cable itself. I leaning towards the cable...
briaineo
Hi gm280
I disconnected all the steering cables, only the outboard sitting on back of boat with nothing at all connected; and is very stiff to push left or right by hand.
thanks
^+1
if that doesnt work, you will need to pull the pivot assembly apart and clean out the corrosion.
Those swivel brackets generally have bushings on top and bottom. As you pump grease into it, the grease will exit the bushing that is gliding smoothly. If you can get grease to exit top and bottom, the motor should free up.
