Mercury 90 L6 ignition
katch_me
Hi, I am hoping to get some answers about my ignition problem on my early 80's 90hp inline 6 (tower of power). So over the last couple of years I have experienced some intermittent starting issues (weekend to weekend). But when it starts it runs great and would always start that weekend. This time when it wouldn't start I wanted to do some troubleshooting. I found NO spark. So here are my questions....
I think it is the trigger assembly. I can rule out the coils (unlikely all 6 stopped working). I can rule out the switch boxes (unlikely both switch boxes went at once). I can rule out the stator (newer stator and the ohms readings match the service manual values). So I say trigger because I was reading very high resistance between the brown and white wires. Service manual says it is way out of spec. Now I hope I got the right wires when I did the test, but I followed the manual to the best of my abilities.
So here are my questions... before I start spending money on parts.
1) When I was looking at this I found that my starter pinion gear is seized in the top position. It still works but my flywheel is grinding it away. So I have metal shavings in the starter/flywheel area. So how does the trigger work? Can the metal shavings be stuck on the flywheel magnets? Is there a chance that i can clean it up and my trigger will work again? Or should I just get a new trigger?
2) Will I have to re-time the motor once I take off the flywheel? Can I just remove the flywheel, don't spin the crank, and reinstall in the exact same place?
3) When I was troubleshooting I put my voltage meter on the green coil output wire, off the switch box. I found when i was cranking the engine i would get only 1 volt DC when the switch box calls for that coil to fire. What is the proper way to troubleshoot the switch box? Should I be getting 12 volts DC there? Or is that AC voltage?
Thanks for any help!!
Faztbullet
Doubt the shavings and trigger is the problem....disconnect harness as my bet is keyswitch or kill switch..
Have battery load tested.----Pull starter apart for inspection / testing.
katch_me
If I disconnect them will I generate spark when I spill the flywheel? What is the best way to bypass the harness and switch and still crank over the motor?
katch_me
Can someone show me a picture of my mercury switch (tilt switch). Have no idea where it is.
katch_me
Maybe the problem is right in front of my eyes. If the starter gear is stripped and worn it won’t turn the crank fast enough to spark. Mmmmmm. Still doesn’t explain the high resistance reading in my trigger. I will have to recheck that.
