Mercury 90 hp Trigger Question
Caskins
Been having problems with my 2000 Merc 90 hp 2 stroke. Decided to check stator and trigger. Stator ohmed good but and sure about trigger. Checking white to purple ohmed opened as expected. Black to brown showed 1.8 ohms. Could this be my problem?
Caskins
The motor is running rough, missing at idle and high rpm’s. Removed and cleaned carbs, didn’t find any problems. Check for fire with inline bulb type spark tester. No fire indication on any cylinder. After running if you pull the plugs, still has wet fuel on the plugs. This is the first time I have ever try to troubleshoot a boat. Thinking electrical problem but I don’t know:
