The motor is running rough, missing at idle and high rpm’s. Removed and cleaned carbs, didn’t find any problems. Check for fire with inline bulb type spark tester. No fire indication on any cylinder. After running if you pull the plugs, still has wet fuel on the plugs. This is the first time I have ever try to troubleshoot a boat. Thinking electrical problem but I don’t know:
