Hi!
My mercury 9.9 4 strokes 201p has a bad idle and no power.
To start it, I need to choke, put in gear at high rev and then push the choke, otherwise it stall.
Sometime, even with the choke the outoard will stall when put in gear or idling.
But my main problem is that there is no power at any throttle position. Even at WOT the motor run very slow like if it was idling.
Sometime, if I let it at WOT a couple of minutes, the outboard will kick in, power will come back and it begin to work properly at every throttle position, but once I stop it the problem come back.
I made a video : https://youtu.be/vP8sn_btwvY
The spark plugs is fine, throttle cable too. The fuel line is not twisted or cut, and when I pump the bulb on the fuel line it change nothing (so its not a fuel pump issue?) Both cylinder compression is at 98psi.
Thanks all.
Thanks all.
