luke.belcher
Thread starter- Joined
- Jan 19, 2011
- 7
I have a '99 Pro Team 175 Special Edition Bass Tracker. It's a 18' aluminum boat. I has a Tacker Marine by Mercury 75hp outboard on it that came with the boat new. The motor as a Aluminum 3 blade prop that has bent blades, hince the question. WHAT PROP IS A UPGRADE FOR THIS MOTOR AND BOAT FOR TOP END SPEED????
The prop with the motor is a Aluminum 3 blade prop with the following numbers on it ( 48 - 77348 - 445 - 21P.
I'm looking for a stainless steel upgrade prop for top speed for the boat.
With the current prop with a 21 pitch, before the blade was bent, performed perfectly. Was great to get on plane and had great holeshot. Top speed with one person was 42-45mph at 5,000-5,500 rpm. Even with the same gear and four people, the boat did not suffer much. Plained good, and would still run wide open throttle at 5,000-5,500rpm but top speed wasn't as much as with one person obviously.
I contacted bass pro shops on this issue also, they gave me the following as replacement props:
Diameter/Pitch Item number
13-1/4 x 15 38-524-310-53
13-1/4 x 17 38-524-310-54
13-1/4 x 19 38-524-310-55
13-1/4 x 21 38-524-310-56
13-1/4 x 23 38-524-310-58
So, any help on prop upgrades would be great guys. Thanks
