mercury 60 hp 3 stroke no fire on pluges
blenkinship
Hey guys<br />I am new and this will be my first poste<br /><br />I have a mercury 60 hp 3 strokes (3 pluges)<br />years I think 1990 electronic <br />the engine will turn but I have no fire (sparks) at the pluges <br />I check the kill sw<br />all wires<br />I have power coming from the stater<br /><br />I think it is the """black box"" electical box<br /><br />Do any one have any sugestion !!!<br /><br />or I should bring it to a dealer and spend a Fortune $$$<br /><br />I would prefere to fix it my self<br />Thanks
AMD Rules
Re: mercury 60 hp 3 stroke no fire on pluges
That is a 2-stroke, 3 cylinder motor. The first thing I would recommend is to get a service manual to help you troubleshoot the electrical system. If you post the serial number, I can confirm the year for you.<br /><br />The black box (switchbox) can be tested with an ohm meter, to measure resistance. I don't have the procedure on hand at the moment.<br /><br />One thing you might want to check is the mercury level switch that would be on the port side of the motor. It is essentially a 'kill' switch. Sometimes they get bumped, or the wires come loose. It would disable the spark to all three cylinders, and is designed to do that when the engine is tilted beyond its operating limit.<br /><br />Did the motor work fine and then just quit suddenly while running, or was it in storage and simply would not re-start afterwards?<br /><br />The factory service manual is best, but both Seloc and Clymer have manuals that are widely available at your local service center. Iboats sells them as well, of course Repair Manuals
blenkinship
The boat was stored for 2 years it work fine back then.storage and simply would not re-start afterwards. <br />Yesterday I got the spark plugs to fire at 2 different time but did not continu<br /><br />as for the mercury level switch, I did not see one !!!<br />I will get the s/n of the engine and come back to you.<br />thanks
blenkinship
On the side opposite of the electrical box, on the cassing it is stamp 12-03-93 !!!<br />and I found under the engine S/N 0G057994<br /><br />Does this help in any way<br />thanks
AMD Rules
Yes, it is listed as a 1994. Nice motor.<br /><br />You may get lucky and just have a loose/intermittent electrical connection somewhere. The switchbox is expensive and well over $400 cdn to purchase. Rather than guess, it is best to follow a defined troubleshooting procedure to verify which component is malfunctioning. This is where a service manual will help.<br /><br />I am not familiar enough with that model year to assist. I do not see a mercury switch in the exploded diagrams. It probably does not have one.<br /><br />Hope it all works out for you.
blenkinship
OK<br />I have called a marina near by, that as the repair manual for the mercury 1994 so I am going to purchase the manual now on special this week for 39.95 can. ???<br />And from there I will see, I will do a bit of trouble shooting and YES i will let you know the out come....<br /><br />thanks<br />The Rock
blenkinship
Ok I have done trouble shooting with the manual (not the best of them ) but seam to have done the job<br /><br />I have removed the """stator""" it seams like it is open circuit so on monday I will bring it to the marina and get it tested <br /><br />at the same time will get the computer box <br />check-out also, now that every thing is <br />de-assemble I should get it all check out write ???<br /><br />will keep you informed<br /><br />P.S. to get to the "stator" it was a hell of a gob needed to fabricate a puller not easy but got it done.<br /><br />Thank you<br />The Rock
