mercury 40 hp sea water cooling failure
shaggro
hi i have a mercury 40 hp outboard may 2003 make.<br />model no- 7041217MF<br />serial no- 0T796245<br />the engine suddenly developed sea water cooling failure. there is no water coming out from behind the engine and it gives alarm when warmed up.<br />i had opened the lower portion of outboard bur there is no blockage. what should i do<br />waiting for ur suggestion to get me out of this tricky situation<br />sharad
mellowyellow
Re: mercury 40 hp sea water cooling failure
welcome aboard,<br />the first step is to install a new water pump kit<br />and impeller.<br />good luck,<br />M.Y.
shaggro
thanks<br />i did replace the old impeller with a new one.<br />how do i go about changing the water pump kit.<br />sharad
mellowyellow
the "kit" is only the impeller and a gasket for<br />the pump housing. did new impeller fix problem?
