mercury 3.0 elbow raiser
Status
Not open for further replies.
Santi
DSCF0116.jpgDSCF0115.jpgHello!I just removed the raiser of my 2006 mercury 3.0 with 80hrs and i was wondering if you guys can tell me if i can still use it? Thanks
JWebber
Re: mercury 3.0 elbow raiser
Salt usage? Looks like you have some restrictions. Is it flowing well?
Santi
Yes salt, 170 degrees when runnig seems to flow well, can i clean it and reuse it? thanks
JWebber
Im thinking a small flex-end rotory type small wire brush, and you can remove quite a bit of that stuff. But be careful it might remove some areas that can open it up and create pits or openings etc...
IES99
Here's a different opinion:
The number of hours it was actually used has only a partial effect on how much corrosion has gone on, since the oxidation occurs with or without water in there.
So: How old is it? When was it first put into use? (I take it 2006?) If it has been used in salt water for 5 years: it's time for a new one
If it were mine and I had it off, I put a new one on there for peace of mind.
Santi
I am using clr and its working very good.
Santi
stingray 185 2006. Used in salt water since march 2006 and always flush with fresh water.
Ayuh,... The Most Important cleaning you need to worry about at this point is the Gasket Surfaces....
In that picture above, it appears water may have started to leak through into the exhaust...
I see 2 spots that look suspect....
They need to be cleaned Shiney Metal Clean, 'n FLAT.....
Mount the piece(manifold, or riser) in a vise, or otherwise Secure,...
Then carefully clean the gasket surface with a Flat File....
Don't take off anymore metal than you have too, 'n keep the surfaces Flat, 'n True....
Good Luck....
Oh,... Use Mercruiser factory gaskets,...
They're a Million times better than the aftermarket gaskets I've found...
Santi
I've got a new mercury raiser and manifold for peace of mind. Thanks anyways
djmakko1
Good Luck....
Please describe Flat file!
Status
