Ideal Compression
dan1979
What is the ideal compression for a 1980 Chrysler 115HP outboard? I plan to check it this evening.
Thanks,
dan1979
Re: Ideal Compression
Anyone out there know the ideal compression ratings for a 1980 Chrysler 115HP outboard?
Thanks!
roscoe
There really are no "ideal" compression levels.
From the factory, 120-140 psi.
Anything over 90 will work.
over 100 better.
dan1979
Checked the compression last night and this is what I got:
#1 - 100
#2 - 110
#3 - 110
#4 - 115
Will the jump from 100 to 115 going to cause any problems? Any thoughts on what it would take to get all 4 to 115, replace gaskets, seals? Overall, I'm happy with the outcome, just curious if its possible to improve. Plus it will give me something to do this winter.... :)
Thanks,
I usually try to stick with the 10-15% difference from the highest to lowest compression cylinders. Some MFG's will say 25% is acceptable. With the numbers you have, you will be ok.
dan1979
Wow, within %25 is acceptable, very cool. Considering how the motor is 28 years old, and I picked it up at a steal of a price, I am impressed with the compression turnout. Thanks!
roscoe
Your readings will be effected by how you did the test.
You will get higher and more consistent readings with the throttle full open, the engine warm, and all plugs removed.
The best thing you can do, is a thorough decarb, to remove the gunk from inside.
Here is a link: http://forums.iboats.com/showthread.php?t=158076
Happy boating.
dan1979
Roscoe, thanks a bunch. I am fairly to outboards, I appreciate all of these tips. I think the motor is ready for an official test on the open water. Thanks again!
