mercury 225 idle rich carbureted
stevewam
1997 225 loads up at idle, right side plugs nice brown and lt side white??? runs good planed out after flooding clears out. need help
Chris1956
Honorary Supreme Mariner
White could mean overheat. Brown is usually a good sign.
Does that motor have a pulse driven fuel pump? If so, the fuel pump diaphragm can leak putting raw fuel into the crankcase at idle. This fuel usually burns off at high RPM, if you can achieve high RPM.
stevewam
just rebuilt fuel pump, no luck
Chris1956
OK, Other causes of flooding are carb floats on one side set too high or inlet needles bad on one side of engine? Idle mixture set wrong on one side of engine? Weak spark at idle on one side of engine (not sure if this is possible)?
You might check the thermostats. Maybe one is stuck causing overheating?
