lacey bluedog
- Sep 9, 2005
- 1
Hi Im new to this Forum so hear goes.<br />I ran a search through this forum with out luck. I have a problem with the trim whilst im at above idle with the engine under load i am not [planning but at around 3000 revs. The trouble is that the motor trims only half way up then shudders and goes slowly back down this does not happen out of the water or whilst planning at speed just while the motor is under load.<br />Checked fluid in resovour which was fine also un screwd the manual lowering nut to see if there was any grit in thread also to no avail.<br />Does anyone had this problem and are there any solutions?<br />Thanks Bluedog
