Mercury 200 EFI losing power
rdclifton
Engine 1996 Mercury 200 EFI
Engine will be running at set RPM (low to full power) then loses power. After a brief time (1-3 minutes) the power will come back and RPMs will increase to original setting. (Example: Engine running at 5000 RPM then drops to 3000 RPMs or lower the after a minute goes regains power back to 5000 RPMs.) Engine does not miss in either instance.
Have swapped power packs will a new spare and tested spark.
Faztbullet
Re: Mercury 200 EFI losing power
Sounds like you loosing a bank of cylinders like a stator shutting down...
