jones19428
Thread starter- Joined
- Jul 8, 2008
- 2
My ob has warning sound even with engine not running only key turned. three wires come to a block terminal on right side of engine if you are looking from back of the motor. I took tan wire off and it does not sound with this wire off, have ruled out over heat sensor and low oil sensor as causing alarm, where does tan wire go, I have tried to look for wireing diagram for this motor on the web but could not find, I,m pretty sure my problem is tied to where this wire goes. can anyone help Thanx Steve
