FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Hi I have a Mercury 115 that the top cylinder is getting significantly hotter than the other 3. The top one is hot but can still be held with your hand. The rest are lukewarm. Any ideas?
How warm should the water be coming from the tell tale hole? The water is only slightly warmer than the lake water. Also the other 3 cylinders are cool to the touch, about room temperature. The top cylinder is hot, but can hold my hand on it. Is this normal or any ideas on what may be causing the issue?
Your pee comes off the exhaust plate and its a indicator and tells you nothing about engine cooling. If impeller is weak even though you think its peeing good its possible the block is not fully filling at idle.Thus top cylinder warmer.....has killed many a TOP motor
Thanks Faztbullet, I will replace the waterpump impeller today. What temp should all the cylinders be? Should they be cool to the touch? The thermostat is 120 degrees. I appreciate all your help!
